Hy,
aktuell ist noch die Hardware der Taranis
Dann kommt die Taranis Plus mit ein paar Änderungen in der Hardware, Stufenschalter, Haptik, intern ein paar Änderungen
Das kann alles für kleines Geld in die bestehende Taranis nachgerüstet werden.
Die aktuelle opentx ist noch die r2940 bzw r2943 und companionv1.52
Dann wird gerade die Software opentxV2.0 entwickelt
Dazu gibt es die Vorabtestversionen V1.99 für opentx und Companion
die in verschiedenen Versionen hier mal reingestellt werden.
Was kann opentxV2.0 mehr als die bisherige, wo soll ich da anfangen:
ich kopier mal hier rein.
Major release, a lot of new features ...
Proportional fonts
Switch warnings can be disabled for switches you don't use on a given model
Compensation for offset error of FrSky FAS-xx current sensors (option on m64)
Measured consumption (mAh) can be stored on power off (ARM-based boards only)
0.1% resolution for limits (ARM boards only)
Sound repeat time settable in multiples of 1sec, call at model load can be disabled (ARM boards only)
3 options for timer countdown voice output (ARM boards only)
Inputs layer with support for all physical inputs and telemetry (Taranis only)
Lua interpreter for runtime scripts and one-time configuration assistants (Taranis only)
9 GVARS instead of 5 (ARM boards only)
GVARs useable for offsets and limits (Taranis only)
GVAR modification popup on home screen can be enabled/disabled for each GVAR (Taranis only)
Output curve assignable to each servo on the SERVOS page (Taranis only)
32 curves instead of 16, with smoothing, and any number of points between 2 and 17 (Taranis only)
64 custom functions instead of 32 (ARM boards only)
New trim system (a mode's trims can be relative to that of another mode's)
Pot position memory for the 4 pots, with startup warning (Taranis only)
Ability to read text files from the SD card. A file with the name of a model will be linked to it and easily accessible as "model notes".
Can be displayed automatically at model load for use as a checklist. (Taranis only)
Copy/paste/insert/delete of custom function lines (Taranis only)
Altitude can be displayed in the top bar (Taranis only)
FrSky Taranis will run at 120MHz instead of 60MHz
Bootloader for Taranis, removes the need to install computer drivers to flash new firmware
SPORT data form internal module available on the UART connector in the battery compartment in the Taranis
Companion merged into OpenTX
Companion major code / graphics refactoring
Radio can handle EEPROM conversion by itself (no need for companion, ARM boards only)
Support for the 6-position pots on Taranis, with individual positions available in the switch selection list
Sticky Logical Switches
ASpd, dTE, Cel-, Vfas- added to Telemetry values
Inproved vario sounds (ARM boards only)
Taranis will be useable as a standard PC joystick through USB, 8 analogs and 8 buttons mapped to CH1-8 and 9-16 respectively
Workaround for newer bogus FlySky modules that send out servo centers on powerup (9x only)
Finnish language support
Default audio files can be placed on the SD card for each model for all switch positions (both for physical and logical switches).
Support for up to 16 channels on trainer input
Einfach nochmal viel mehr
da wir schon lange mit V1.99 arbeiten fällt das uns gar nicht mehr auf
Im aktuellen deutschen Handbuch ist davon das meiste schon drinnen.
im Anhang als pdf gezipt
Helle
