Da die Bixlers eigentlich umgelabelte Skysurfer sind und der Bixler1 einem frühen Skywalker entspricht und der Bixler2 dem V5er Skysurfer entspricht kann der Bixler3 eigentlich nur der Super Skysurfer mit 2,4m sein.
Im RCGroups Forum vermutet jemand, dass es sich um einen umgelabelten Sky Surfer V5 handeln wird, der hat laut Website auch andere (verbesserte) Features als der Bixler 2:
http://www.bananahobby.com/5-ch-blitzrcworks-sky-surfer-v5-rc-sailplane-glider-arf.html
New Version 5: Able to interchange from 3CH / 4CH / 5CH by locking/unlocking the Aileron/Flaps control surfaces
New Version 5: Designed for beginners to change or move up their flyign skill levels
New Version 5: Nose is made of hard durable plastic nose cone for perfect impact resistance for nose diving
New Version 5: New folding prop design(Better performance, agility, and durability)
New Version 5: Bottom fuselage and main wings with plastic surface covers for not damaging the fuselage and servo horns when belly landing
New Version 5: No glue required for assembly(Easy to assemble, repair, and maintenance)
New Version 5: Fuselage nose with plenty of room(Excellent for FPV usuage or upgrading to larger higher capacity batteries
New Version 5: 2x carbon spars for main wings and 1x for elevator for extra stiffness and rigidity
New Version 5: Reliable high quality electronics( EX. Hobbywing 30A ESC)
New Version 5: Wings are bolted to fuselage and can be unassembled for easy transportation
Hört sich alles ganz gut an
